I'm performing a convergence study on the attached model. The idea is to run multiple simulations for the same model using different mesh sizes, and then determine the appropriate mesh size for this model to guarantee accurate S-parameter results.
The simulations were performed using custom meshing for 3.5 mm, 2.5 mm, 1.5 mm, 1.0 mm, 0.5 mm in all of these trials the S-parameter plots were different.
Thank you.
