Hi ,
I wanted to mesh a lot of lines with variable lengths in model by using tcl script, but I found the sample script in help is not intelligent, for example
*createmark lines 1 15 18
*linemesh_preparedata lines 1 30
*linemesh_saveparameters 0 3 0 0
*linemesh_saveparameters 1 2 0 0
*linemesh_savedata1 1 5 0 0
The parameter 'density' in line 3 and 4 are manually assigned, and the 'segment' and 'density' parameteres must be strictly matched. If the length of each line are different, the density are also different. So, a lot of *linemesh_saveparameters commands are needed. It is not acceptable for this meshing scripting.
So, is there a way to mesh lines with constant element size?
