Hi, everyone.
I encountered a problem when I reflected a model with area connectors. The model is symmetric, but the whole model must be analyzed in some cases. I reflected the original half model (half model.hm) about xz plane of AxisSystem1 (ID=1) by using *duplicateentities and *reflectmarkwithoption and *equivalence commands, then merged the same components and load collectors. However, the analysis of the symmetry model (symmetry.hm ) cannot be executed properly and gives too much errors such as,
*** See next message about line 47237 from file:
E:/HyperWorks_Work/Symmetry/Symmetry.fem
'RBE3 26648 23617 0 22003 23619 23620 23621'
This line was interpreted as:
47237:RBE3, 26648, , 23617, 0, 22003, 23619, 23620, 23621
*** ERROR # 1000 *** in the input data:
Incorrect data in field # 5.
Expected COMPONENT numbers, found INTEGER (0).
Incorrect data in field # 7.
Expected COMPONENT numbers, found INTEGER (23619).
*** See next message about line 47238 from file:
'RBE3 26649 16110 0 23623 16111 16112 16113'
47238:RBE3, 26649, , 16110, 0, 23623, 16111, 16112, 16113
The errors in .out file reflect that the RBE3 elements in the reflected Glue component have wrong information. The RBE3 elements seem not to be reflected properly.
BTW, the half model can be analyzed normally.
I don't know where the problem is. Can anybody gives me some advices?
Thanks.
