I would like to generate a SHAP interpretation for a model I have stored in the repository. Is this possible? It doesn't seem to work.
<?xml version="1.0" encoding="UTF-8"?><process version="9.9.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.9.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.9.000" expanded="true" height="68" name="Retrieve G_D_SVM-RFE_DT" width="90" x="246" y="34">
<parameter key="repository_entry" value="//Local Repository/Models_SVM-RFE/G_D_SVM-RFE_DT"/>
<operator activated="true" class="retrieve" compatibility="9.9.000" expanded="true" height="68" name="Retrieve gland_trainSet_stable" width="90" x="112" y="136">
<parameter key="repository_entry" value="//Local Repository/gland_trainSet_stable"/>
<operator activated="true" class="multiply" compatibility="9.9.000" expanded="true" height="103" name="Multiply" width="90" x="246" y="136"/>
<operator activated="true" class="interpretation:generate_interpretation" compatibility="0.1.001" expanded="true" height="124" name="Generate Interpretation" width="90" x="447" y="85">
<parameter key="algorithm" value="Shapley"/>
<parameter key="sample_size" value="100"/>
<parameter key="redraw_local_samples" value="true"/>
<parameter key="explanation_algorithm" value="Correlation"/>
<parameter key="locality" value="0.2"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<connect from_op="Retrieve G_D_SVM-RFE_DT" from_port="output" to_op="Generate Interpretation" to_port="mod"/>
<connect from_op="Retrieve gland_trainSet_stable" from_port="output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Generate Interpretation" to_port="training"/>
<connect from_op="Multiply" from_port="output 2" to_op="Generate Interpretation" to_port="test"/>
<connect from_op="Generate Interpretation" from_port="importance" to_port="result 1"/>
<connect from_op="Generate Interpretation" from_port="global weights" to_port="result 2"/>
</process>
</process>
Thanks in advance,
Ana
