Hi all,
Just like HM APIs such as hm_info, is there a way to find out which directory compose is installed in?
I do not want to look up an environement variable, unless that is the only way.
Does anyone have any tips for me?
Thanks, Deb
Deb,
In Compose v2020, you can use composedir function and in previous versions you can use getenv('ALTAIR_HOME') to get the environment variable that points to Compose installation folder.
Roberta
