Is there any way of obtaining the airgap flux linkage and rotor flux linkage in an induction motor with solid stator and rotor bars? Thank you.
To compute the flux linkage in your case you need to create a sensor type predefined and you select magnetic flux on face or face regions. So for the rotor you select face region rotor and for the air gape you select face region air gap.
To create the sensor :
Parameter/quantity >> Sensor >> right click, select new
Best regards.
Alright, Thank you.
you are weclome.
