Hey all,
When I simulate wires with loads (using wire ports) and perform CMA, the loads disappear in postfeko. Does FEKO consider the loads when performing CMA?
Dear ZakariaI have tested in Feko 2022.3.2 and can confirm that in this version the loads are shown correctly in POSTFEKO.Could you confirm which version of Feko you are using?Additionally, you could try running a simple test such as a single wire dipole with and without a load added to see if the CMA solution produces different results with and without the load as expected.
Kind regards,
Johan H
