Why HoltWinters Forecast returns null?
DylanZZZ
DylanZZZ New Altair Community Member
edited November 5 in Community Q&A
Simple Process
Only one attribute with no missing
Param of Holt-Winters
Param of Apply Forecast
However, it gives nan prediction
What happens??
  • DylanZZZ
    I have figured out. That's because there are zeros in data. So, how to train model with zero value?
  • YYH
    YYH
    Hi @DylanZZZ,
    Glad to see you figured out by your self. The trick to handle zeros could be, re-scale data and add a small "error" to every example. For instance, using the formula
    b0*10+0.01   ------>> b0'
    to transform your original input b0, and make all zeros become 0.01 or even smaller (anything > 0 works).
    You will forecast the new re-scaled value, and inverse it back using (b0' - 0.01)/10
    Hope it helps.
    YY
  • David_A
    David_A New Altair Community Member
    I think the problem in your case is a combination of a very short seasonality value (are you sure about this, it would mean you have a pattern of length two in your data) and the zero values. In that case you will get segments in the model training, where very likely a division by zero or something similar happens.
    Best,
    David
