hi everyone,
i am trying to model a single wire termenated with 50 ohm impedance at both of its termenals. the wire is above a PEC ground and i use a plane wave as excitation to plot the induced current at the terminals. the problem is that this error massege always appears' knowing that i am using fine mesh' :
ERROR 39693: A cable end point should be defined within 0.2 wavelengths of a metallic triangle vertex. Please use a finer mesh around such cable end points.
and i dont know what is the 'metallic triangle vertex'.
