hi, i am trying to use aluminum for my design but its not appear for me as a choice. i only can add dielectrics. can you help me with that please?
thanks
Hi @MOHAMED HAMDALLA,
At higher frequencies, the skin depth of a metallic region quickly limits how deeply electromagnetic waves can penetrate a 3D object. In FEKO, then, the method to model a metal is to:
See for an example. Note that I've also change your frequency settings to a single 1GHz frequency point. You can, of course, change it back to a frequency range but I wouldn't expect the results to make sense all the way down to 1Hz. The geometry is in the order of 22cm long, which is electrically a very small object at lower frequencies.
thank you very much. is this mentioned in the FEKO manual or even examples?
You can maybe look at the Examples Guide. Example D-1 is 'Shielding factor of a sphere with finite conductivity' which is conceptually similar. There is more information on the formulations in the User Manual (look for the description of the 'SK card') but this might be a bit too much detail for your purposes.
