Hi all,
I am trying to simulate two wires with loads. I am uploading each wire points from a .txt file. When I am trying to run the file it shows an error that I didn't assign a wire segment ports for the loads. However, they are defined in lines [52-56]. I have attached my editfeko file and wire points files to check if you can help me with this problem.
Thanks
