Hi all,
If I loop over multiple field incident angles in FEKO and calculate Modal excitation coefficient, The calculated curve will be the results of which angle?
I have attached my file to be clear if the question is confusing.
Thanks
Currently a CMA configuration with modal excitation coefficients where the source is a plane wave loop over multiple angles of incidence will only consider the final angle of incidence.
