hi, i am trying to reproduce the results from thesis for the field to wire coupling. the wire is terminated at both ends with 221 ohm impedance. i got the same resonances in as the thesis for one end on the wire correctly but not the same amplitude as the published results. Also the other wire end gives completely wrong results. can anyone please help me with that to know what is the problem.
the thesis is also attached and the results are shown in pad 27.
thanks
