Hi all,
I am trying to create an arbitrary wire using Editfeko. the problem is there is no option to generate fitted spline in Editfeko as Cadfeko. I have points that need to be fitted in a curve line like the attached line in my Cadfeko file. My Editfeko is also attached. If anyone run both files he will see a shift in the results because of the descountouniouies in my Editfeko structure.
Thanks
Hello MOHAMED HAMDALLA,
As you have noted, EDITFEKO does not have a fitted spline and we don't intend to extend EDITFEKO (or rather the RPEFEKO language) to have it in the future. Your options are:
Thanks for your reply. I am trying to automate feko with Matlab. I can upload my points to Editfeko every time I run it but I don't know if there any way to import and mesh these points in Cadfeko using Matlab.
