🎉Community Raffle - Win $25
Join and Win
exporting multiple results
User: "Zakaria"
Altair Community Member
Updated by Zakaria
hi, i am now modeling field to wire coupling. i used plane wave with multi incident angles to excite the wire. the voltage results of this configuration are more than 20 curves. is there any way to extract (export) all of these data simultaneously in the same  file ( without the need of extracting all of the results one by one)' as i eventually need to get the average of all of these curves'. i am asking about this because this is just the beginning and i may need to export much more results in the same file.
thanks
1 - 1 of 11
    User: "Altair Forum User"
    Updated by Altair Forum User
    Hi Mohamed, have you considered doing the postprocessing in POSTFEKO? Have a look at the Enable maths function for 2D curve plots ... it is possible e.g. to add several curves in this manor to calculate the average easily.
    Alternatively, you may need to use Lua scripting to export the data simultaneously.
