I am trying to calculate the coupling to a wire above a dielectric cube for different wire orientation. So the structure is a fixed cube and a wire with variable orientation. Therefore i am using parametric sweep because i thought this may save the computational time. I know that the impedance matrix of the cube it self and the wire by it self should not change but only the coupling matrix. but as the parametric is sequential process it takes longer time than having multiple FEKO files ruining in parallel. Can anyone please help me to find out away to save the matrices of the individual parts in my structure to make the simulation faster or if any one has any idea to make it faster for the same parts but just different orientations.
Hint: Domain Green's Function Method (DGFM) option is checked.
Thanks
