Radioss Parallel computing SPMD
Hi Subhu,
Please go through this document http://www.altairuniversity.com/wp-content/uploads/2013/12/1036.pdf which explains about HyperWorks solver run manager.
0 -
Thanks George. Can I have an example hostfile and appfile.
-Subhu
0 -
For SPMD run overs multiple server, you have to setup a CLUSTER.
Without cluster, you can not run SPMD.
0 -
Does the above process also needs to set up cluster??
If so, is it possible to setup virtual cluster with Ethernet connection?
0 -
Technically, you can run SPMD on multi-core CPU with some MPI. But with only one server!
So I don't think you got advantage comparing to SMP run on the same server.
Cluster setup is NOT a easy job, and NOT for everyone /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
