What is the difference between Wheel in Trailing Arm Mono shock and Wheel part in Rear tire. Where to set the mass for the wheel and for the tire ?
Regards
Draucis
hi Draucis,
You can check the body which is assosiated with Autotire(shown below). The complete wheel/tire assembly mass can be applied within the panel 2nd page (property files) and keep the negligible mass for the wheel/wheel part. Even you apply some mass to wheel/wheel part and remaining to inside autotire panel. But make sure that total wheel/tire assembly should be matched with the actual measured/designed value.
To cross check the mass and inertia info, you can go to Tools menu -> CG/Inertia Summary
thanks,
jagadeesh
hi Draucis, You can check the body which is assosiated with Autotire(shown below). The complete wheel/tire assembly mass can be applied within the panel 2nd page (property files) and keep the negligible mass for the wheel/wheel part. Even you apply some mass to wheel/wheel part and remaining to inside autotire panel. But make sure that total wheel/tire assembly should be matched with the actual measured/designed value. To cross check the mass and inertia info, you can go to Tools menu -> CG/Inertia Summary thanks, jagadeesh
Hello Jagadeesh,
Yes, now I am clear about things and yes, the CG/Intertia Summary is a tool which I use a lot. Thanks Again
