For the two-wheeler model, is it possible to have a hub-mounted motor? can I give the powertrain body the coordinates for the rear wheel center and delete the chain solution dummy?
Regards
Draucis
Hello Draucis,
Hub mounted motor should work (I haven't tried it though). You can delete the chain solution dummy.
Please make sure all the connections/attachments are properly maintained. If you face issues, please post again.
Raghavendra.
