I'm trying to run a extrusion analysis but keep coming up with this error message after starting analysis " EW_BATCH Failed: can't read "::HX_PMW::comp_elem_size(Land_L1)": no such variable". I've tried following the tutorial videos. I've changed my tooling drawings to simple one layer tube extrusion but still getting the same error. Also tried following the tutorial video that was under Altair Polymer Extrude section but no luck .
Any help would be greatly appreciated,
Darius.
