Hello, i have a question about altair inspire structural simulation. I want to use topology optimization for my research and its running smoothly until i need to analyze the result. Why i always get failed when im analyze the topology optimization result and it says that i need to contact altair support. the announcement shows like this.i really really need your help, thank you
Hey Muhammad,
You need to check if there are some intersect with other component.
Sometimes is interesting refine the smooth interactions, like below
Cheers!
Marcus Hamann
Hi marcus,how to check if there are some intersect with other components? i already changed the smooth level to high and increase smoothing iterations to 100 but it's still failed like the first picture i asked.
Please refer this to avoid intersection between parts/components - https://2021.help.altair.com/2021.1/inspire/en_us/topics/shared/glossary/gloss_collision_detection_t.htm
