How can I change and fix default variables like sleeve type, metal and mold type etc. in Inspire Cast. I want to fix them so that I don't have to change it every time when starting the software.
Thanks,
Jas
Hi Jas,
From my knowledge I don't think there is a way to do that without running a script. I also do not know of any scripts that specifically do this available for download on the Script and Model library. Inspire does have a python editor that can be accessed by pressing "F4" or through the "view" pull down menu. Hope that helps!
Dakota
This is not available in Inspire cast, and it is annoying.
Some variable are kept, and most of them not.
When you open new file you need always to check all variables.
Already asked for this option in the past...
