Hello, everyone. I want to do mesh convergence analysis of a 3D model, by using the maximum von Mises stress as the tested variable. However, I want to compare that maximum von Mises stress with the changes of number of elements, like from 10,000, 20,000, 30,000, instead of changing the mesh size.
What I know so far is that we can only modify the mesh size. But is there any function to set the desired number of elements? Thank you for any advice
