Currently I am facing a problem where I intended to remesh the elements produced from using element offset feature as shown below:
I want to make the mesh of that flat surface becoming trias as well using 2D -> automesh, as shown below:
However, that rectangular meshes didn't change at all after the process. The meshing only affected the surface above it (the surface of the original body).
Therefore, is there any way to make that thickened surface becoming the same type of mesh like the other region? Thank you for your kind attention
