If I create a temp node in HM2019 (or select a node to measure using F4), the full Geom/ Mesh is zoomed out to be at very far. If you use FIT option, the whole mesh is seen as a speck somewhere. It is tough to zoom in and go near the mesh to select the second node of measure.
How to avoid this. It is very difficult to work on HM because of this error.
Please see error snapshot. The actual mesh is a 7'x4' interior monument FEM (FYI)
