how can I set the material orientation of the 2d elements along the circumferential direction of this ring profile?
picture attached.
thank you,
arh423
Try creating a cylindrical system, and assign material orientation 'by system axis'
Thank you, it works.
It is possible to set the orintation along a curve?
I cannot find the option in HM13.
Go to 2D page>>Composites>> Material orientation>> select the elements and click review.
Thank you, it works. It is possible to set the orintation along a curve? I cannot find the option in HM13.
maybe you need a script. a relevant tcl command is *element2Dalign.
try searching it on script exchange
