Using Timer element to retry when errors occur
We have a visual process within Automator that errors out due to a prior process importing a large file.
Error: The process cannot access the file 'Reports\CRJ Weekly\Downloads\Monarch Input\BP_AUD200G1-50W_10_01_2020.txt.x1xhc4b.partial' because it is being used by another process.
It was mentioned in a training session to use a retry feature. I've added it to the below process but was not sure if the retry element has the entire process restart or just a specific element. Is the below process correct or should I have both Export elements feed into one timer/retry?
Please note that both Dataprep Export processes is where the error mentioned above occurs.
Thanks in advance
Tony
Tony Ruffy
Sr Analyst
