Stop process and send email notifications when no input file available
Is there a way to stop a Visual process within Automator and send an email notification when no input file is present? I've tried using Verify Model and Verify workspace but was not successful. I've also tried using alerts but the process still continues and sends a completion email that is setup at the end of the process when it completes.
Thank you!
Tony Ruffy
Sr Analyst
Best Answer
Hi Tony,Tony_20992 said:Thank you Steve, I will look to setup a similar structure. Curious, is Hub component required to use Verify Workspace?
Tony Ruffy
Sr Analyst
Gap Inc Store Labs
San Francisco CA
505-462-0613
Original Message:
Sent: 09-30-2020 04:44 AM
Subject: Stop process and send email notifications when no input file available
Hi Tony,
Much depends on the structure of the process, but you can usually get this behaviour by choosing "Stop" in the verify options.Although not related directly to your question, I'd also like to point out the "failed" path that is available from many nodes (including verification, export, scripts) by right clicking on the canvas and showing advanced connectors. This gives you the ability to follow a separate path if something fails . . .
In this case, you would usually select the "Continue with verified only" option in the verification node, but it does depend on your process structure.
Steve.
Steve Caiels
Professional Services
Altair
Original Message:
Sent: 09-29-2020 01:21 PM
Thank you!
Tony Ruffy
Sr Analyst
Sometimes!
For example, you can verify AFTER a Data Prep export without using a hub. This is useful in terms of alerting and maybe triggering a different flow from the 'failed' path; but an empty file has already been created by this stage. To verify BEFORE export, you need a hub. This allows you to abort the process before an empty file is created.
Steve.
Steve Caiels
Altair
Original Message:
Sent: 09-30-2020 10:00 AM
Tony Ruffy
Sr Analyst
Gap Inc Store Labs
San Francisco CA
505-462-0613
Original Message:
Hi Tony,
Steve.
Steve Caiels
Altair
Original Message:
Thank you!
Tony Ruffy
Sr Analyst
Hi Tony,
Steve.
Steve Caiels
Altair
Original Message:
Thank you!
Tony Ruffy
Sr Analyst
0 -
Thank you Steve, I will look to setup a similar structure. Curious, is Hub component required to use Verify Workspace?Steve Caiels_21881 said:Hi Tony,
Steve.
Steve Caiels
Altair
Original Message:
Thank you!
Tony Ruffy
Sr Analyst
Tony Ruffy
Sr Analyst
Gap Inc Store Labs
San Francisco CA
505-462-0613
Original Message:
Hi Tony,
Steve.
Steve Caiels
Altair
Original Message:
Thank you!
Tony Ruffy
Sr Analyst
0 -
Tony Ruffy
Sr Analyst
Gap Inc Store Labs
San Francisco CA
505-462-0613
Original Message:
Hi Tony,
Steve.
Steve Caiels
Altair
Original Message:
Thank you!
Tony Ruffy
Sr Analyst
Sometimes!
Steve.
Steve Caiels
Altair
Original Message:
Tony Ruffy
Sr Analyst
Gap Inc Store Labs
San Francisco CA
505-462-0613
Original Message:
Hi Tony,
Steve.
Steve Caiels
Altair
Original Message:
Thank you!
Tony Ruffy
Sr Analyst
0 -
Thanks again Steve, this makes better sense.Steve Caiels_21881 said:Hi Tony,
Sometimes!
Steve.
Steve Caiels
Altair
Original Message:
Tony Ruffy
Sr Analyst
Gap Inc Store Labs
San Francisco CA
505-462-0613
Original Message:
Hi Tony,
Steve.
Steve Caiels
Altair
Original Message:
Thank you!
Tony Ruffy
Sr Analyst
Tony Ruffy
Sr Analyst
Gap Inc Store Labs
San Francisco CA
505-462-0613
Original Message:
Sent: 10-01-2020 05:02 AM
Hi Tony,
Sometimes!
Steve.
Steve Caiels
Altair
Original Message:
Tony Ruffy
Sr Analyst
Gap Inc Store Labs
San Francisco CA
505-462-0613
Original Message:
Hi Tony,
Steve.
Steve Caiels
Altair
Original Message:
Thank you!
Tony Ruffy
Sr Analyst
