i get an error with not properly definded loadsteps.
But this loadstep and the corresponding id does not exist in the Model Browser.
But I found the laodstep (I think an old one) in the Entity State Browser.
How can I delete it????
Thank you!
It seems like an issue. You can clear temp file. In delete panel you can search with ID to load. And if it find any load or loadstep or loadcol anyway you can delete. Can you try this way ?
It worked, thank you!!!
If your loadstep is inactivated in the Entity State browser you just need to reactivate it and the go to model browser and delete it.
