Hi EDEM Engineering,
I have simulated the particle breakage using particle replacement, and it works on CPU (using the functions:createParticle and calculateForce). How to transfer it to the GPU API. The tutorial in Script&Model Library only lists the contact model-related GPU API examples. Can I use the GPU API to simulate particle breakage using particle replacement?
Thank you!
Dazhao
