Hi EDEM Engineer,
I have implemented the particle breakage (based on Breakage model_CCM_2_3_CF_2_1) and work well at version EDEM 2020.3. While when I updated the EDEM version 2021.2 and setting the same as before, all the particles in the current timestep were replaced by predefined small particles. Are some parameters have been revised in the new version API?
By the way, When I go back to version 2020.3, the previous code also did not work at EDEM2020 (the part "CHertzMindlinWithBreakage::setup" didn't run and the particle cannot be replaced by small particles even at very small breakage forces). Are some environments were covered by the new version of EDEM?
Thank you!
Dazhao Gou
