Hey,
While doing the analysis in the Tool Defleciton, I encounter this error (TDB Batch Failed/Preprocessing of model - Failed) and the analysis stops.
It gives TDB_Batch_Failed error. Can you help?
I have attached the files.
Dear @Oguzhan Senyuva
Narendra gave you an answer, but there is additional information, so I am replying.The contents of the test are as follows.
step 01
step 02
step 03
step 04
Attachementfrom_HM_05.x_t: done by HyperMeshfrom_HM_05_merged.x_b: Modified and merged models20230207_Tool_Deflection_Memo.pptx: Note what I have been tested
MemoIf you proceed with one model, it would be good to refer to the attached model.Extrusion analysis and tool structure analysis are not attached because the process conditions may be different from aluminum materials.
Thank you,
Sung-Moon Kim
Thank you very much for your feedback. When I add the .hmascii file that I obtained from the extrusion analysis, the analysis seems to be working but there is no progress. Do you know about the reason for this?
Oguzhan
I'm glad to hear that my answer is helpful.
I have questions.Attached is an example of the training material.Is it possible to check if the attached file can be analyzed without any problems?The reason why I'm sending you an example is to see if the extrusion analysis proceeds without any problems on the computer.The example of the training works well, I need the following data to solve your issues.1. Extrusion analysis model (*.iem, *.hmascii)2. Tool deflection model(*.iem)If you send me the above data, I will review it and give you an answer.
Thanks and Best Regards,Sung-Moon Kim
Dear @Oguzhan Senyuva I'm glad to hear that my answer is helpful. I have questions.Attached is an example of the training material.Is it possible to check if the attached file can be analyzed without any problems?The reason why I'm sending you an example is to see if the extrusion analysis proceeds without any problems on the computer.The example of the training works well, I need the following data to solve your issues.1. Extrusion analysis model (*.iem, *.hmascii)2. Tool deflection model(*.iem)If you send me the above data, I will review it and give you an answer. Thanks and Best Regards,Sung-Moon Kim
I performed the analysis of the attached file without any problems. When I start the analysis, it gets stuck as seen in the picture. Attached are the files you want. I can't understand where I went wrong.
Thanks
I checked extrusion model with the model you attached.I think that model was looks no problem.
I am attaching the demo video and analysis result file, so please refer to it.
Attachment(You can download it by clicking url below.)https://ftam1.altair.com/message/gUgqZVzClfLAnzx7Urvseb1. demo_video.mp42. TOOL_DEF_2A-Run03_results.zip
I think it would be good to check in the order below for the contents to proceed.1. Delete Scratch Files(You can contact the nearest Altair office for how to delete the scratch.)2. Check if the computer name is only in English(with number is OK).3. Check if the analysis execution path is only English(with number is OK). 4. Verify that the installation is success.
I think it would be good to refer to the contents below and try it again for the installation method.
----------------------------------------How to install----------------------------------------1. Download the installation file The computer name and installation path must not contain special characters.2. Quit the whole ALTAIR S/W3. During integrated installation, install with administrator privileges. ※ For your reference, please be sure to inactive anti-virus program before installation. When extracting the installation files, some files may be recognized as viruses.----------------------------------------------------------------------------------------------
