Hey,
I want to do dummy block analysis. Can someone help on how to do it?
Oguzhan
More information on exactly what you are trying to accomplish will be helpful in directing your question to the appropriate forum.
I want to see the loads on the dummy block, the heat values it reaches and the thermal expansions. I performed the flow analysis on the mold, but I could not add the dummy block and analyze it. An instruction on how to do it in general would be good.
Note: I could not analyze the loads on the die, I got TDB_Batch_Failed error.
I want to see the loads on the dummy block, the heat values it reaches and the thermal expansions. I performed the flow analysis on the mold, but I could not add the dummy block and analyze it. An instruction on how to do it in general would be good. Note: I could not analyze the loads on the die, I got TDB_Batch_Failed error.
Do I need to analyze the die for dummy block analysis?
Thanks.
Any progress? I couldn't find how to do the analysis.
