Hey,
I am getting the attached error while performing metal extrusion die analysis. There is no problem when performing flow analysis, but it comes out in the die. What is the cause of the problem? How can I solve it?
Thanks.
Hello @Oguzhan Senyuva ,
Thank you for contacting us. Can you please attach the model that you are working on? That will help us trace what is the actual reason for which yo are getting this error.
Thanks,
Narendra Singh
Hello @Oguzhan Senyuva , Thank you for contacting us. Can you please attach the model that you are working on? That will help us trace what is the actual reason for which yo are getting this error. Thanks, Narendra Singh
@Narendra Singh I have attached the files as attachments. Thanks.
Is there any progress? @Narendra Singh
Do you have any solution suggestions?
Without a model, it's impossible to find out why your model failed. Can you attach Status-EWB.log file if you are unable to attach your Inspire Extrude file. This log file will have information at what point the batch processing failed.
I am sharing the file I encountered with an error in the tool deflection section. The file I used as the model is also included. I can get results without any problems in the extrusion part, but I have a problem with tool deflection. The log file you mentioned is in the extrusion section and contains no errors. I left the log file in the zip file in a separate folder. I'm waiting for your help. I don't have much time for my project submission @Narendra Singh Download Link: https://file.io/VJFThNCxXl0E
Thank you for sharing the model file. I found a few issues with the model and will fix them and send them over to you.
Once I have the results, I will summarize that are tips to setup the model so that you can avoid this issue.
I have attached the corrected file.
Here are few recomendatation for you :
1. Cutting solid for Porholes and WeldChamber
2. Porholes start:
Portholes has steep fillet and this might cause issues in meshing. For such models, it is recommended to have 10mm of billet and some portholes as Feeder
3. Load faces for Die and Mandrel have more selection than needed.
I hope this help with your project.
Here are a few results:
Thank you,
Narendra singh
