I changed iris-classification samples of Keras to 2 target classes (deleted just one class in the database) and sat the number of units parameter in core layer two to 2 (output class). It didn't work and gave the shape error (attached). I tried with various conditions and had the same problem. Any thought?
Regards. Mansour
<?xml version="1.0" encoding="UTF-8"?><process version="9.3.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process" origin="GENERATED_SAMPLE">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.3.001" expanded="true" height="68" name="Retrieve Iris" origin="GENERATED_SAMPLE" width="90" x="45" y="289">
<parameter key="repository_entry" value="//Samples/data/Iris"/>
<operator activated="true" class="filter_examples" compatibility="9.3.001" expanded="true" height="103" name="Filter Examples" width="90" x="179" y="289">
<parameter key="parameter_expression" value=""/>
<parameter key="condition_class" value="custom_filters"/>
<parameter key="invert_filter" value="true"/>
<list key="filters_list">
<parameter key="filters_entry_key" value="label.equals.Iris-setosa"/>
</list>
<parameter key="filters_logic_and" value="true"/>
<parameter key="filters_check_metadata" value="true"/>
<operator activated="true" class="split_data" compatibility="9.3.001" expanded="true" height="103" name="Split Data" origin="GENERATED_SAMPLE" width="90" x="313" y="289">
<enumeration key="partitions">
<parameter key="ratio" value="0.9"/>
<parameter key="ratio" value="0.1"/>
</enumeration>
<parameter key="sampling_type" value="automatic"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<operator activated="true" class="keras:sequential" compatibility="1.0.003" expanded="true" height="166" name="Keras Model" origin="GENERATED_SAMPLE" width="90" x="447" y="187">
<parameter key="input shape" value="(4,)"/>
<parameter key="loss" value="categorical_crossentropy"/>
<parameter key="optimizer" value="Adam"/>
<parameter key="learning rate" value="0.001"/>
<parameter key="momentum" value="0.0"/>
<parameter key="rho" value="0.9"/>
<parameter key="beta 1" value="0.999"/>
<parameter key="beta 2" value="0.999"/>
<parameter key="epsilon" value="1.0E-8"/>
<parameter key="decay" value="0.0"/>
<parameter key="schedule decay" value="0.004"/>
<parameter key="Nesterov" value="false"/>
<parameter key="use metric" value="false"/>
<enumeration key="metric"/>
<parameter key="epochs" value="128"/>
<parameter key="batch size" value="32"/>
<enumeration key="callbacks">
<parameter key="callbacks" value="TensorBoard(log_dir='./logs', histogram_freq=0, write_graph=True, write_images=False, embeddings_freq=0, embeddings_layer_names=None, embeddings_metadata=None)"/>
</enumeration>
<parameter key="verbose" value="1"/>
<parameter key="validation split" value="0.0"/>
<parameter key="shuffle" value="false"/>
<parameter key="fix seed" value="false"/>
<parameter key="random seed" value="0"/>
<operator activated="true" class="keras:core_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Core Layer" origin="GENERATED_SAMPLE" width="90" x="179" y="289">
<parameter key="layer_type" value="Dense"/>
<parameter key="no_units" value="8"/>
<parameter key="activation_function" value="'relu'"/>
<parameter key="use_bias" value="true"/>
<parameter key="kernel_initializer" value="glorot_uniform(seed=None)"/>
<parameter key="bias_initializer" value="Zeros()"/>
<parameter key="kernel_regularizer" value="None"/>
<parameter key="bias_regularizer" value="None"/>
<parameter key="activity_regularizer" value="None"/>
<parameter key="kernel_constraint" value="None"/>
<parameter key="bias_constraint" value="None"/>
<parameter key="rate" value="0.1"/>
<parameter key="noise_shape" value="None"/>
<parameter key="seed" value="None"/>
<parameter key="target_shape" value="(1, 1)"/>
<parameter key="dims" value="1.1"/>
<parameter key="repetition_factor" value="2"/>
<parameter key="function" value="None"/>
<parameter key="l1" value="0.0"/>
<parameter key="l2" value="0.0"/>
<parameter key="mask_value" value="0.0"/>
<operator activated="true" class="keras:core_layer" compatibility="1.0.003" expanded="true" height="82" name="Add Core Layer (2)" origin="GENERATED_SAMPLE" width="90" x="313" y="289">
<parameter key="no_units" value="2"/>
<parameter key="activation_function" value="'softmax'"/>
<connect from_op="Add Core Layer" from_port="layers 1" to_op="Add Core Layer (2)" to_port="layers"/>
<connect from_op="Add Core Layer (2)" from_port="layers 1" to_port="layers 1"/>
<portSpacing port="sink_layers 1" spacing="0"/>
<portSpacing port="sink_layers 2" spacing="0"/>
</process>
<operator activated="true" class="keras:apply" compatibility="1.0.003" expanded="true" height="82" name="Apply Keras Model" origin="GENERATED_SAMPLE" width="90" x="648" y="289">
<parameter key="batch_size" value="16"/>
<parameter key="verbose" value="0"/>
<connect from_op="Retrieve Iris" from_port="output" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Split Data" to_port="example set"/>
<connect from_op="Split Data" from_port="partition 1" to_op="Keras Model" to_port="training set"/>
<connect from_op="Split Data" from_port="partition 2" to_op="Apply Keras Model" to_port="unlabelled data"/>
<connect from_op="Keras Model" from_port="model" to_op="Apply Keras Model" to_port="model"/>
<connect from_op="Apply Keras Model" from_port="labelled data" to_port="result 1"/>
</process>
</process>
