Optimize Parameter/Log for Decision Tree
Prentice
I'm trying to compare different algorithms and try to find the optimal parameters. For this, I use the optimize parameter operator. However, when I try to apply it to a Decision Tree classifier it doesn't work. Or at least, the log function doesn't work properly, but I also get the same accuracy for each setting.
But when I want to plot it in a log function it only shows one value for each parameter.
Does somebody know why this happens and how I can solve it?
Thanks
Prentice
Decision Tree
jczogalla
Hi
@Prentice
That sounds strange indeed. I will look into this to see if this is a potential bug.
Edit:
I looked at your process and I think I see the culprit. In the
Log
operator, you reference the
Decision Tree
operator, not
Decision Tree (2)
, which is
used inside the cross validation, as well as it being referenced in the optimize parameters. Also, there should be a log called
Optimize Parameters (Grid)
, which should already have the parameters and performance as a log. I hope this helps!
Cheers
Jan
sgenzer
hi
@Prentice
so I looked at your process and if I put a breakpoint right before Optimize Parameters, I see an ExampleSet with SIX examples. There is no way you are going to build a machine learning model with such a small data set. This is why your "accuracy" is always the same, etc..
Scott
Prentice
Hello
@sgenzer
Aah, so this means that my actual ExampleSet is also too small? I've got like 150 examples with 4 classes, that does explain it. It just goes each time to the same branch, hence having the same confidence.
But why does the Log operator not work when I try to use different settings for the Decision Tree? It shows the combinations in the Optimize Parameters results, but it shows the same combinations for each iteration for the results of Log. This only happens when I use the Decision Tree.
Prentice
jczogalla
Hi
@Prentice
Edit:
Log
Decision Tree
operator, not
Decision Tree (2)
, which is
Cheers
Jan
Prentice
@jczogalla
Wow thanks, sometimes the most simplest of things get overlooked. I can't believe I spent hours trying find the cause and it's something like this haha.
Anyway, thanks for your help!
Prentice
