Hey,
i have the following setup of an freesize composite optimization:
response mass, response wcomp
objektive minimize mass, constraint wcomp (defined lower boundary)
Also defined max. laminate thickness=8mm and min. laminate thickness 1,6mm, DSIZE mindim=40mm
So i want to minimize the mass till the lower boundary of the wcomp constraint is reached.
But somehow my wcomp constraint is violated and the resulting mass is exaktly the mass of the whole laminate with min. thickness of 1,6mm. Why is my constraint not working?
Thank you!
