<?xml version="1.0" encoding="UTF-8"?><process version="9.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.1.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.1.000" expanded="true" height="68" name="Retrieve Iris" width="90" x="45" y="238"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="concurrency:cross_validation" compatibility="9.1.000" expanded="true" height="166" name="Cross Validation" width="90" x="246" y="85"> <parameter key="split_on_batch_attribute" value="false"/> <parameter key="leave_one_out" value="false"/> <parameter key="number_of_folds" value="5"/> <parameter key="sampling_type" value="automatic"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="h2o:deep_learning" compatibility="9.0.000" expanded="true" height="82" name="Deep Learning" width="90" x="179" y="34"> <parameter key="activation" value="Rectifier"/> <enumeration key="hidden_layer_sizes"> <parameter key="hidden_layer_sizes" value="50"/> <parameter key="hidden_layer_sizes" value="50"/> </enumeration> <enumeration key="hidden_dropout_ratios"/> <parameter key="reproducible_(uses_1_thread)" value="false"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="epochs" value="10.0"/> <parameter key="compute_variable_importances" value="false"/> <parameter key="train_samples_per_iteration" value="-2"/> <parameter key="adaptive_rate" value="true"/> <parameter key="epsilon" value="1.0E-8"/> <parameter key="rho" value="0.99"/> <parameter key="learning_rate" value="0.005"/> <parameter key="learning_rate_annealing" value="1.0E-6"/> <parameter key="learning_rate_decay" value="1.0"/> <parameter key="momentum_start" value="0.0"/> <parameter key="momentum_ramp" value="1000000.0"/> <parameter key="momentum_stable" value="0.0"/> <parameter key="nesterov_accelerated_gradient" value="true"/> <parameter key="standardize" value="true"/> <parameter key="L1" value="1.0E-5"/> <parameter key="L2" value="0.0"/> <parameter key="max_w2" value="10.0"/> <parameter key="loss_function" value="Automatic"/> <parameter key="distribution_function" value="AUTO"/> <parameter key="early_stopping" value="false"/> <parameter key="stopping_rounds" value="1"/> <parameter key="stopping_metric" value="AUTO"/> <parameter key="stopping_tolerance" value="0.001"/> <parameter key="missing_values_handling" value="MeanImputation"/> <parameter key="max_runtime_seconds" value="0"/> <list key="expert_parameters"/> <list key="expert_parameters_"/> </operator> <connect from_port="training set" to_op="Deep Learning" to_port="training set"/> <connect from_op="Deep Learning" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="9.1.000" expanded="true" height="82" name="Apply Model" width="90" x="45" y="34"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="multiply" compatibility="9.1.000" expanded="true" height="103" name="Multiply" width="90" x="112" y="187"/> <operator activated="true" class="performance" compatibility="9.1.000" expanded="true" height="82" name="Performance" width="90" x="179" y="34"> <parameter key="use_example_weights" value="true"/> </operator> <operator activated="true" class="performance_classification" compatibility="9.1.000" expanded="true" height="82" name="Performance (2)" width="90" x="246" y="187"> <parameter key="main_criterion" value="first"/> <parameter key="accuracy" value="true"/> <parameter key="classification_error" value="false"/> <parameter key="kappa" value="true"/> <parameter key="weighted_mean_recall" value="false"/> <parameter key="weighted_mean_precision" value="false"/> <parameter key="spearman_rho" value="false"/> <parameter key="kendall_tau" value="false"/> <parameter key="absolute_error" value="false"/> <parameter key="relative_error" value="false"/> <parameter key="relative_error_lenient" value="false"/> <parameter key="relative_error_strict" value="false"/> <parameter key="normalized_absolute_error" value="false"/> <parameter key="root_mean_squared_error" value="false"/> <parameter key="root_relative_squared_error" value="false"/> <parameter key="squared_error" value="false"/> <parameter key="correlation" value="false"/> <parameter key="squared_correlation" value="false"/> <parameter key="cross-entropy" value="false"/> <parameter key="margin" value="false"/> <parameter key="soft_margin_loss" value="false"/> <parameter key="logistic_loss" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> <list key="class_weights"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Multiply" from_port="output 2" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="performance 1"/> <connect from_op="Performance" from_port="example set" to_port="test set results"/> <connect from_op="Performance (2)" from_port="performance" to_port="performance 2"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_test set results" spacing="0"/> <portSpacing port="sink_performance 1" spacing="0"/> <portSpacing port="sink_performance 2" spacing="0"/> <portSpacing port="sink_performance 3" spacing="0"/> </process> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Cross Validation" to_port="example set"/> <connect from_op="Cross Validation" from_port="example set" to_port="result 3"/> <connect from_op="Cross Validation" from_port="test result set" to_port="result 2"/> <connect from_op="Cross Validation" from_port="performance 1" to_port="result 1"/> <connect from_op="Cross Validation" from_port="performance 2" to_port="result 4"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> <portSpacing port="sink_result 5" spacing="0"/> </process> </operator> </process>
