Using characteristic mode configuration, one can obtain eigenvalues, modal significance, etc. I would like to know if the corresponding eigenvector values can be exported and read.
Thanks.
From my exchange with FEKO, this seems unavailable on FEKO but hopefully someone from their support can clarify
This is not available. During a characteristic mode analysis FEKO does not export the *.str file and thus the eigen vector for CMA is not currently available to the user.
Hello! you could export the Z matrix using another environment and get the real and the imaginary parts of the Z matrix , then you can get the eigenvectors.
