I would like to learn the .lua script of the MIMO Performance Evaluation for the calculation of envelope correlation coefficient (ECC). What does 'intFactor' and 'Gainfactor' exactly stand for and how does the algorithm work to calculate ECC?
Thanks.
Hello @hykr
Due to copywrite we are probably not allowed to share academic here. But if you do a literature search you will find that the formulas for the different MIMO performance parameters are wildly published. Our implementation are based on the standard formulas. I hope this helps.
Peter
