Every time I try to use feko I get an error saying it couldn’t check my license. I followed the forums and made sure my ID is the same. The one I entered when I signed up is the same one that showed when I used ipconfig/all. What do I do now?
If it is a floating license (server-based), make sure the Altair License Manager is installed, up and running. You then need to define the environment variable ALTAIR_LICENSE_PATH=6200@LicenseServerHostName (put in the correct host name of your license server).
