🎉Community Raffle - Win $25
Join and Win
Automesh and surface problem
HMuser_20961User: "HMuser_20961"
New Altair Community Member
Updated by HMuser_20961
Hi all,
I am using Hypermesh 2017.
I see following problem in creating a mesh.  The geometry is a surface.
I presume that this is a result of bad surface geometry or partition.
Could anyone highlight me any possible way to fix this surface problem?
Thanks in advance.
1 - 1 of 11
    Hello HMuser,
    this mesh can result from a degenerated surface. Indeed, for such a simple surface, neither bouding elements nor mesh with batchmesh/QI optimize should lead to such results. Then I would recommend to remove the surface and to rebuild it.
    Best Regards,
    Michael
