Hi RM team, seems to be a very basic calculation, but can't create an expression for the following scenario.
I have example set with Positivity values (positive, neutral, negative). I'm using aggregate operator to perform counts for all example set.
Have table as output in the following format:
Positivity(Att1) Count of Positivity (Att2)
Positive 500
Neutral 100
Negative 500
I then need to generate another Attribute (positivity %), which needs to have a ratio value based on positive/negative values from att2.
What is the proper expression to use in this case?
Thanks!
