Hex mesh of irregular shaped bodies
Natalia_20940
Natalia_20940 Altair Community Member
You have a set of complex, irregular shaped enclosed surfaces (mitochondria and myofibril inside muscle cell).
You want to mesh these only using solid hex elements using a quite coarse mesh (the geometry can be simplified and smoothened).
How would you go about it?
  • Koushik Chandrashekhar_21806
    edited March 2020
    Hi Natalia,
    Kindly go through the attached document having guidelines on 3D meshing.
  • Q.Nguyen-Dai
    Q.Nguyen-Dai Altair Community Member
    edited March 2020
    Depending on your geometry, maybe it's possible, or not. No general rule for this work.
  • Rahul_P1
    Rahul_P1
    edited April 2020
    Have you considered simsolid, which can analyse complex geometries like body parts without any need for meshing?
  • Q.Nguyen-Dai
    edited April 2020
    I tested alot with SimSolid. It's nice tool for designer, but NOT for FEA Engineer :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
