Hello there,
I am currently setting up a model of a composite pressure vessel which is build up via a filament winding process. Because of how the pressure vessel is build there is a hole in the dome regions. At one side I do constrain every node around the whole completly in all DOFs (123456). At the other side I am trying to set up appropriate symmetrical boundary conditions, similar to some papers regarding pressure vessels.
The vessel is perfectly symmetric regarding the xz and the yz plane, my research shows that i need to constrain the perpendicular direction to the xz (or yz) plane and the rotiational DOF parallel to each plane, which I just did as the picture above shows. The vessel is pressurized with a pressure of 200 MPa.
My results visualized via HyperView are not what I expect and I assume that is because my boundary condtions are not correct. The results I expect should show me that the stress maximum is reached in the cylindrical part of my pressure vessel. If I do constrain every DOF at the top end of my vessel I do get that results (but this is mechanical definitly not correct because my vessel is not constrained that way).
I assume i need to somehow constrain every node along its symmetrie plane, but I do not know how I can achieve that with HyperMesh.
Do you guys have any idea how I can change my boundary conditions to be reasonable?
Thanks alot for your advice
Best regards
cluue
