I have some problems to send my model from hypermesh to hyperview. When I do optistruct, the software doesn't create the right file to allow me to use hyperview. Some help?
The software generates H3D file which you can use to post process the results in Hyperview.
In case, it is not generating the H3D file, go through the following posts about the same issue which were discussed earlier.
