I'm trying to import a file from FLUX software, I export the geometry from FLUX in .IGES and .STEP. In both extension the imported geometry in hypermesh is uncomplete, some solids there are, other no. some lines are ok, other are free lines with no connection. I found a lot of problem in rebuilt the geometry with no succes.
How can i fix this problem? is there someone how can works with both programs with no problems?
Grazie!
