How to get normal x of vector created by two nodes
Hi Jouher,
Please try this:
*vectorcreate_twonode $node1 $node2; *createmark vectors 1 -1; set ::vectorCord [ hm_getmark vectors 1 ] set x [ hm_getentityvalue vectors $::vectorCord 'xcomp' 0 ];
*createmarkpanel nodes 1 'Select N1...' set n1 [hm_getmark nodes 1] hm_markclear nodes 1
set n1x [ hm_getentityvalue NODES $n1 'globalx' 0 ] set n1y [ hm_getentityvalue NODES $n1 'globaly' 0 ] set n1z [ hm_getentityvalue NODES $n1 'globalz' 0 ]
*createmarkpanel nodes 1 'Select N2...' set n2 [hm_getmark nodes 1] hm_markclear nodes 1
set n2x [ hm_getentityvalue NODES $n2 'globalx' 0 ] set n2y [ hm_getentityvalue NODES $n2 'globaly' 0 ] set n2z [ hm_getentityvalue NODES $n2 'globalz' 0 ]
*createmarkpanel nodes 1 'Select N3...' set n3 [hm_getmark nodes 1] hm_markclear nodes 1
set vec1x [expr $n2x - $n1x] set vec1y [expr $n2y - $n1y] set vec1z [expr $n2z - $n1z]
set n3x [ hm_getentityvalue NODES $n3 'globalx' 0 ] set n3y [ hm_getentityvalue NODES $n3 'globaly' 0 ] set n3z [ hm_getentityvalue NODES $n3 'globalz' 0 ]
set vec2x [expr $n3x - $n2x] set vec2y [expr $n3y - $n2y] set vec2z [expr $n3z - $n2z]
set vecx [expr $vec1y*$vec2z - $vec1z*$vec2y] set vecy [expr $vec1z*$vec2x - $vec1x*$vec2z] set vecz [expr $vec1x*$vec2y - $vec1y*$vec2x] *createmark nodes 1 236 *createvector 1 $vecx $vecy $vecz *translatemark nodes 1 1 5
Do u want to translate the node 236 along created vector from 3 node selection or 2 node?
