I want to write a contents to a file which is opened. and it should append to it live!!!
File writing at each instant should be read by user at the same time. Is it possibe?
How does user read it?
Hi Jouher,
I don't see any issue with it, the file will be appended by default when using append mode , to view it live you will have to modify settings in your code editor.
https://www.tutorialspoint.com/tcl-tk/tcl_file_io.htm
Livil
If I could understand Jouher, read a file everytime it is appended similar to monitor a process output (like solvers):
- hw12 and formers: use tail.exe in .../hw/etc/bin/win64 (many funny executables else are there!)
- From hw13: tail.exe disappears.
Hi there..
It seems that you are extremely expert at this from your updates. I am a new user of Hypermesh and a student from Denmark. May I ask you some questions about the meshing export. The issue is that I am now using edge finite element, so I really need the edge information (the number of edge and two nodes number of each edge). I know we can see that from tool but is there possible to export it as a text file?
Best,
Longying
What kind of 1d element is that edge FE?
