*createmark lines 1 'by comp id' $compid not working.
And is there a way/api to get most repeated line (size -length wise) in the CAD
@tinh
Above cmd just works with free lines
With topo lines, must mark surfaces by comp and then mark lines by those surfs
Or try using *findmark
Line has no dataname for length, the only way is to iterate then compare length to filter lines with same length
